Recently I have overwritten an LRS service from ArcGIS pro into portal. After it ran, I received the green completion message. When I looked at the service in Portal, the new layer I added to the service appears in the REST API for that feature service as well as the map image layer of the service. However the layer does not appear in the feature layer of the service. If I bring the whole service into ArcGIS pro the layer does not appear, but if I expand the portal service under the portal tab the layer appears and I can drag it into the map with data. It does not show if I bring in the whole service. Any thoughts on why this is happening?
