I have multiple clients that use WebGISDR with consistently good outcomes. However, I have one that is struggling and I can see no valid reason for this.
We're on a change freeze for ArcGIS Enterprise Content, and there really isn't a lot of content in there at this point. The backup files are always ~2.5GB which is pretty standard for a newish deployment.
The scenario is this. I restart the VM to make it nice and fresh. The webgisdr runs on a schedule at 2AM and takes about 25 minutes. There are no performance problems during the day. On Day 2 it runs at 2AM and takes 50 minutes. On Day 3 it takes nearly 2 hours. On Day 4 it takes nearly 4 hours and on Day 5 it takes nearly 8 hours. Remember, no change in content during this five-day period.
The webgisdr logs are showing that both the portal and server exports are taking longer each day, the datastore and packaging completion times remain consistent.
Transaction logs are being cleared every day. There is no growth in storage on the E:.
The client uses a local physical host, which is then virtualised down using VMWare as the hypervisor. The machines are thinly provisioned for disk, CPU, RAM (8vCPUs and 64GB RAM). There is a single host with the base deployment on it, and no federated servers. The ArcGIS application and content is on the E: of the machine. Webgisdr is configured to write to the local F drive (also SSD). The components write to F:\Temp and then these files are packaged to F:\compile. There are no network/UNC paths, and everything is local. The output file that is created on the F: is then moved to a folder share using a different separate script on a separate scheduled task. This keeps all operations using local disk only.
Using monitoring software, I see no changes in CPU/RAM characteristics during the backup window. It just takes longer each day. CPU/RAM are generally sitting at 20-30% for the duration.
If I run the process manually, then the process monitor is showing disk reads/writes in the Kb not the Mb. It's shockingly slow. Even file operations outside of GIS are slow.
When running the installer (MSI) the install was pretty quick. However, patching (MSP files) take 4-5 times longer than a typical client.
I've asked for full provisioning and for the malware to be temporarily disabled. That can't be done for operational reasons.
My gut is saying this is not an Esri issue, but I'm looking to see if anyone else in the community has a similar story or even a fix?
