Has anyone into this issue of the feature dataset view breaking and seeing the evw. If yes, what is the solution?
It's a table view from a tyler system. I am not sure if it was in a csv or xls.
The user updating the data is not the sde or dbo user, the table was owned by a dbo user.
The SQL Server is a SDE schema Restoring the last backup is something we are looking at, but it would be nice to resolve this issue and still have the nightly import.
Yeah, it looks like the geodatabase part of the database is broken.Any idea what the "nightly import" is that they did?Is the Enterprise Geodatabase a DBO or SDE schema?It may be best to work with technical support on this.The other option is restoring the last verified backup and work from there. You may potentially loose some work.
Hi George,
This issue is what I am seeing both on an operating system and database authentication.
Everything was looking good until yesterday. IT help setup a nightly import in the sql server using a dbo user. Which I am 90% sure that it triggered the issue.
@George_Thompson
This screenshot looks like what I would see with a non-geodatabase on SQL Server.How was the connect made? Can you provide a screenshot, block out the sensitive information?When was the last time that connection looked "correct"?
