I want to use the Survey123 Assistant with ArcGIS Enterprise.How do I enable AI in ArcGIS Enterprise 11.5?If it is not implemented - Why?
Ok, found it, it is hidden here:
Was looking in the wrong place, as I thought the setting was in the same place as in ArcGIS Online:
https://doc.arcgis.com/de/arcgis-online/administer/configure-assistants.htm
But that screenshot is from ArcGIS Online right? I don´t see any documentation regarding ArcGIS Enterprise so I´m not sure if it´s implemented
@Pili Yes, In ArcGIS Enterprise 11.5 I expected to see the AI Assistant Setting in the same place as ArcGIS Online, but it is missing. So I was asking myself how to enable the Assistant in Survey123 for use with Enterprise. Turns out, it is directly to be found in the Survey123 Settings.AI Support in Enterprise is supposed to come in a future release (still based on ArcGIS Online for the time being)
Exactly! I tried it and I agree with you.
@SimonSchütte_ct I've seen it working in ArcGIS Enterprise 12 , you just need an ArcGIS Online admin account, to set it properly.
