I have an application built with Ex Builder Dev Edition version 1.17. The filter table by map extent is not working for me. I have set a trigger in the map widget as all the instructions I see have advised (see for example the screenshot in this post https://community.esri.com/t5/arcgis-experience-builder-ideas/experience-builder-filter-table-by-map-extent/idi-p/1279978) But when I do that, the records in my table all disappear. Same thing if I select "Filter by map extent" in the Table widget.Has anyone else encountered this? Is there a setting I am missing? Thank you!
Hi Shen,
The rows themselves are still there, but all the data disappears. Also, the record count at the bottom left of the table also clears and says Total:0 |Selection: 0. Also, the small filter icon at the top right of the Table grays out and clicking on it does nothing so you cannot undo the filter action.
I did discern a new detail though: the problem seems to only exist for linear data (roads, railways, rivers, etc.). The tool seems to work correctly on point and polygon data.
Hello @EMiller_2, when the 'Filter by Map Extent' tool is enabled, were you unable to see the records or rows completely, or are the rows displayed but all the cell values are empty? Even if the rows are displayed with empty cell values, you can still see the total number of records and selections on the bottom left corner of the table widget.
The empty rows issue is one that we're aware of and are working on. However, if you see that the table is empty, it would be nice to provide a screenshot and some sample data for us to investigate. Thank you!
