I have SharePoint list containing X and Y points. It's working fine in the map as points.
What if I want them to be displayed as polygon?? What I should change or do?
Where are you seeing those points (e.g webapp, esri maps for sharepoint)) ??
You can use ArcGIS Desktop to transform those points in polygons. There are few ways to do that. Check this suppport technical article:
How To: Convert a point feature class to a polygon feature class
I'm using (Esri maps for SharePoint). I will check the article as well.
My suggestions or simple way is process the point data to be a polygon ( polygon shapefile - zip ) , before share in ArcGIS Online. Polygon is series on xy coordinates, not list of point objects. For example us use ArcMap , QGis, etc.
how to upload shapefile to sharepoint?
Shapefile sharing must include minimum of three files, .dbf, .shp. shx. Suggest .prj also. Find these files in the output location of your shapefile, zip them up and then post to sharepoint. Optionally, you may include all the shapefile extensions too.
thank you. but I didn't get it very well! where to upload them in sharepoint? and how call them in Esri map for sharepoint?
