Hello everyone.
I'm editing polygons in ArcGIS Pro 3.4.2, but when I split the polygons using the (SPLIT) tool, it's not displayed in the image, but the split is visible in the attribute worksheet. Can you help me by telling me how to configure it to fix this situation?
Best regards.
Repair Geometry (Data Management)—ArcGIS Pro | Documentation
Check Geometry (Data Management)—ArcGIS Pro | Documentation
I forgot, I'm working within an stero model.
Hi Dan
Yes, the files are in the same coordinate system. They're edits I'm making on a Stereo model.
Hi Daniel
The files aren't from ArcGIS Online, they're a GDB. I went into the domains and changed them to Duplicate. But there was no result. And regarding the "geometry checker/geometry repair," I don't know how to do it.
Hi @JairoCordero
Have you run a repair geometry/geometry checker for any bad points/vertices?
If the data is coming from ArcGIS Online as a WFL can you toggles the True Curve option that is in the settings of the layer with the item details page? Initially toggle off this setting and see if this makes a difference, make sure to save the setting change.
Is the map and the featureclass in the same coordinate system? There were issues for this situation, but apparently resolved, but worth a check.
something else too
BUG-000166353 for ArcGIS Pro
