Hi all, I learn GIS as I go and I'm usually able to figure things out eventually, but sometimes I'm missing the appropriate search terms. If I have a table like the one below and I want to symbolize budget range by dot size, where many records will fall into the same FIPS codes, how would I aggregate the budget total for each FIPS code. In the past, I did the work in the file prior to adding to ArcGIS but I'm wondering if there's a feature/tool that will easily do this or whether writing an expression would suffice (if so, extra thanks if anyone can get me started on that expression!) TIA!
objectID | Shape | st_abr | FIPS | budget |
1 | point | TX | 48001 | 100 |
2 | point | DC | 11001 | 500 |
3 | point | TX | 48001 | 800 |
4 | point | AZ | 04001 | 250 |
5 | point | AL | 04001 | 300 |
6 | point | TX | 48001 | 980 |
7 | point | CT | 09001 | 850 |
8 | point | AZ | 04001 | 300 |
9 | point | DC | 11001 | 970 |
10 | point | NH | 33001 | 540 |
