Our organization is currently on Enterprise 10.9.1 and likely upgrading sometime next year. I am having what seems to be a glitch in the 'new map viewer'. We have created a web map with some services and a few groups with individual layers. We would like to set a default view in the web map with only certain layers toggled on. We do not want to change this in the underlying ArcGIS server services as they are used in other applications. We also want to avoid making a new service for this as our number of instances is on the high side already.
I have 2 services that I would like only some of the layer turned on. I can toggle some of the layers off in service A and they will show up properly. Once I change some of the layers that are on by default in service B, service A reverts to the default layer visibility in the underlying service. I am only able to adjust the layer visibility in only one service in the web map. I have tried turning on dynamic layer support in the services but there is no difference.
I tried the same thing ArcGIS Online and it allows for the adjustment of layer visibility for multiple services. Unfortunately, I can not use ArcGIS Online for this application.
Is there a setting I am missing somewhere. It would seem my only option would be to add each individual layer from the service and the add to a group. I tried this for one of the services and the draw performance takes a hit.
