Good afternoon
My organisation has created a new enterprise geodatabase in SQL Server. We have created a data owner user for the new EGDB that was used to load various feature classes into the new database. During the data loading, several attribute rules were created on the new feature classes. These seem to execute as expected.
I have subsequently created a new data editor user on the EGDB that has all the required permissions to SELECT, INSERT, UPDATE, DELETE.
This new user generally seems to behave as expected. I am able to read/load the different feature datasets. However, when I try to create a new feature in any of the datasets that have an attribute rule applied I get an error message ("Failed to evaluate Arcade expression. [Rule name: Calculate Unique ID, Triggering event: Insert..."). I am not able to add any new features, although interestingly I am able to edit existing features within the feature classes with attribute rules.
Checking the attribute rule window, it gives a message that says "The table or feature class corresponding to this view is read-only". This doesn't seem correct as I am able to modify the feature class, I just can't add new features.
Furthermore within the new data editor user I am unable to add/edit/delete attribute rules. However, if I use the data loader user to remove the attribute rules, I am then able to create new features using the data editor rule.
In short it seems that only the data owner is able to create and execute attribute rules on feature classes. Other users with sufficient privileges are unable to create features within the feature classes if there is an attribute rule in place. The data editor is also unable to execute/edit/delete existing attribute rules.
Just wondering if this is expected behaviour? Is it possible to for attribute rules to be created and executed by a user other than the data owner.
Thanks for your consideration.
