Hello erveryone,
Is there a way to use ArcGIS Online Basemaps in an offline scenario (using ArcGIS Enterprise and FieldMaps) without having an ArcGIS Online account? The customer only uses ArcGIS ArcGIS Enterprise.
Thanls everybody
Matthias
As far as I know, Esri basemaps require an connection to ArcGIS Online, and there is no direct way to use them offline in ArcGIS Enterprise without an ArcGIS Online account. To use basemaps offline, you'll need to either create and publish your own basemaps using ArcGIS Pro or obtain basemap data from other sources and host them in your ArcGIS Enterprise environment.
Thanks Michael.
But is it possible to use the Basemaps offline without using any AGO-User?
You can, but it takes some special configurations. It is documented here in the section called "Use an Esri basemap offline" Take web maps offline—Portal for ArcGIS | Documentation for ArcGIS Enterprise
They key is that you must manually create an item "from URL" in Enterprise, connect to the AGO URL for the basemap, and then provide and store credentials to AGO using a built-in account. Share the new item to a group or your Org.
Then, users of Enterprise will be able to connect to the AGO item using the credentials that you stored. They must be logged into Enterprise, no anonymous access allowed.
