Hello @GISER
Based on your what you are describing I think you can do it with only the exteriorshell of each digital model. with the assumption that 1 digital model represent a single building.
Are you doing all the 140 digital models into a single BSLPK ?
David
thanks @DA_BIM-GIS for your support,
actually all models are displayed Exterior Shell only 😂.
No i generate SLPK for each BIM model (.rvt).
Also I read that the Navisworks (.NWD) is a light format of BIM models, I don't sure but if yes is there a way to migrate into GIS!
if you are doing the exteriorshell only, i will not recommend doing BSLPK as you will be carry extra geometry (elements) that you don't need. I will published the exteriorshell as 3D objects.
Also, ArcGIS Pro does not read Navisworks natively, but if you want to use that route you wll need to convert the navisworks files into FBX ( I will recommend reducing the number of polygons so the files are of manageable size) and then import the .fbx into Pro.
You could try using Make Building Layer to create a light weight composite layer for visualization.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/make-building-layer.htm
