All,
I am using Power Automate to help automate a portion of a project's workflow. Unfortunately, I'm running into issues and my Flow is failing.
Here's the goal: user updates an attribute in an ArcOnline hosted feature layer. When that attribute is changed to a certain value, we need that feature (polygon and some attributes) to be copied to another hosted feature layer.
I've attached screenshots of my current Flow, but am having issues with getting the polygon to be copied. I can get the attributes copied: what happens is a attributed record is created but there is no geometry associated with it. I think it all has to do with the "Geometry" attribute in the "Create a record in a feature layer," but I can't figure out what to put there. I've tried all kinds of combinations. What am I doing wrong? Just a note, too: I haven't added the condition portion of the Flow yet that identifies the attribute and value that should trigger the copying of the record (I want to get the geometry copying portion to work first!).
@SeanKMcGinnis
@AnthonyLatini
