Using Portal 11.1 and rebuilding a WAB / Dashboard app from scratch thanks to forced migration. I have 4 dashboards that are essentially identical but just differ due to a time based definition query on the data. I've mocked up one Dashboard so far and I thought I could just do a "save as" on the dashboard and then just subsequently change the underlying map that the dashboard uses.
Apparently this can't be done? The only option I see is to remove the map completely and then re-add it (which will also remove all the chart widgets I spent time setting. Tell me I'm wrong- is there no easy way to swap maps used by a Dashboards app? Can I use ArcGIS Assistant to do this as a hack?
Steve
