It would help to have a ROW_NUMBER function in FDGB SQL.
The ROW_NUMBER() is a window function that assigns a sequential integer to each row of a query’s result set. Rows are ordered starting from one based on the order specified by the ORDER BY clause in the window definition.https://www.sqlitetutorial.net/sqlite-window-functions/sqlite-row_number/
Use cases:
I'm curious: Are you not able to pull the ObjectID field for this purpose?
@MErikReedAugusta
The ObjectID is static. I want a dynamic row number within a sorted query.
Like this: Select the four largest cities.
objectid in ( select objectid from (select objectid, row_number() over (order by population_2021 desc) as rownum from cities) where rownum <= 4)
This works in a mobile geodatabase. And there are enterprise geodatabase equivalents. But as far as I know, there isn't a function like ROW_NUMBER in file geodatabase SQL.
Or if window functions are too difficult to implement in FGDB SQL, then maybe a ROWNUM pseudo-column would work, similar to what Oracle does:
objectid in ( select objectid from (select rownum, objectid from cities order by population_2021 desc) where rownum <= 4)
Related:
Calculate Field with sequential numbers, partition by GROUP_ID field, order by VALUES field
A ROW_NUM pseudo column would also help with Join — Control what related record gets used.
In a FGDB database view:
ORDER BY on the grouping ID/common ID field, then on the field that we want to prioritize for the one-to-first join, so that the desired row is at the top of each grouping. Reason: one-to-first joins use the related record that has the smallest object ID.Replace the real OBJECTID field with a fake/new OBJECTID using ROW_NUM.
Sign in to post, follow content, and more. New here? Register for free.
