We are getting the following error in the logs when logging into portal. SAML sign-in error: Invalid_SAMLResponse: Unable to login using Idp. 'NAME_ID' not found in SAML response. When you click on sign in it redirects to the login screen then it works. It will also work when using a bookmark. The error only shows when typing in the direct link " https://xyz.xyz.xyz/portal/home". Has anyone seen this error before?
@Craig_Lunde Have you checked this?https://support.esri.com/en-us/knowledge-base/error-unable-to-log-in-using-idp-nameid-not-found-in-s-000026098
