I want to chang my server domain name from "machinename.domain.com" to "machinename.newdomain.com"How can i change my domain name by saving my all portal content
WebContex-URL ? WebAdapytors ?
Any Experience in this matter?I'm using ArcGIS 10.8
Need to change domain name of ArcGIS Enterprise (S... - Esri CommunityOrganization URL—ArcGIS Enterprise | Documentation for ArcGIS Enterprise"If you need to change the hostname in your organization URL, contact Esri Professional Services or another trusted consulting partner for guidance."
Hello @olamendel ,
I concur with what @MarceloMarques suggested. To add to that my recommendation (based on personal experience) when changing machine names is that you have to do a fresh install of the software. Why?
The reason is that ArcGIS Enterprise writes the machine name to deep parts of its configuration.
You can change the name of an ArcGIS Server node but not Portal, so you will be stuck with that at least
For ArcGIS Server : https://enterprise.arcgis.com/en/server/latest/administer/windows/common-problems-and-solutions.htm#anchor11
Hope it helps!
-Archit
