I have a series of photos that were taken with a camera with no onboard GPS. Instead, we mark ground control points and record their location with a cm-accurate TotalStation, which are then matched up with the photos to produce a high-accuracy orthomosiac & DEM. TotalStation points are usually more accurate than a drone GPS for our application (archaeology). I usually process data like this in Agisoft Metashape, where it is easy to tell the software to ignore the GPS data and only use the imported GCP locations. I'd like to replicate this process in Drone2Map, but I have been unable to figure out how to use Drone2Map with images that lack inherent GPS coordinates. Is it at all possible to do this in Drone2Map or am I out of luck? Thanks for any help.
