Hello and welcome back to another episode of Telecom GIS in 5 minutes.
In this episode we will be discussing a next-gen network management workflow that covers high level design creation, online collaboration, and walkout surveys both from the office and field.
This workflow is designed not only to give you more accurate high level cost estimates and distance for your network expansion, but also allows user in your organization to share and collaborate on it and eventually use that information to determine feasibility in the field.
Network Path Planner Solution - https://doc.arcgis.com/en/arcgis-solutions/11.0/reference/introduction-to-network-path-planner.htm
TGI5 Episode 035 (Network Path Planner) - https://community.esri.com/t5/telecommunications-videos/tgi5-episode-035-network-path-planner/td-p/1117486
Walkout Survey Solution - https://doc.arcgis.com/en/arcgis-solutions/11.0/reference/introduction-to-walkout-survey.htm
TGI5 - Episode 039 (Getting Started with the Walkout Survey Solution)
-https://community.esri.com/t5/telecommunications-videos/tgi5-episode-039-getting-started-with-the-walkout/m-p/1126121
ArcGIS Experience Builder - https://doc.arcgis.com/en/experience-builder/latest/get-started/what-is-arcgis-experience-builder.htm
