What is the purpose of having map image layers in addition to hosted feature layers on the portal?
In what situations are map image layers more effective than hosted feature layers?
Thank you.
To me, the main limitation of hosted feature layers are symbology and labels.
You can’t have hatch or symbologies like arrows on lines to represent slopes and other complex symbology. In the same way, the labelling engine is not as powerful as what can be done server side and result many times in overlapped labels.
For all those reasons, I can’t manage our GIS solely with hosted feature layers.
Maps SDK 4.X solved the issue of renderering many features at the same time which could also have been one reason to choose Map image Layer over feature layer for some dataset.
There must be others but that the main ones on top of my head.
Thanks @NicolasGIS.
I'd like to add a few points and add some references to our docs for more info.
Ref:
hope this helps
oh one other thing - there are cases when you want to add a layer as a feature layer in a web map for client side drawing and interactivity. You can still do that by using the url of a layer inside a map service. for example:
Thank you both. This is very helpful.
Thanks @AlizaNaz for providing additional info.
Just a quick clarification -- Map image layer (aka map service) doesn't necessarily mean 'cached/tiled map service'.
There are two types of map services:
Hi @TanuHoque ,
When you mentioned "an author can configure a map service such a way that end users won't have access to download all data" - what way are you referring to? I'm using a feature layer added from a map service. I can't find a way to restrict download of data from a feature layer added from a map service. I'm using Enterprise 11.1 and ArcGIS Pro 3.1.5. It seems like ArcGIS Server Manager Service mapping operations allowed are not listened to in ArcGIS Pro. Unless I turn off both Query and Data in the Map Service operations allowed (in which case I can't add a feature layer from a map service anyway).
Thank you,
Andrea
