Hello - I've posted on this before, the webgisdr utility failure at 11.0 due to a federated server web adaptor name 'agsfed' containing at least one letter in the word 'a-d-m-i-n'.
I am happy to report that issue seems to have been resolved. However, the utility is still failing, or rather, it is completing but not producing an output file:
\AeScripts\ArcEntAdminTools\webgisdr111\webgisdr>webgisdr --export --file
\AeScripts\ArcEntAdminTools\webgisdr111\webgisdr\myfullsitebkup.properties
Starting the WebGIS DR utility.
The configuration and base backup time in the current Web GIS
Portal: https://myorg.net/portal at 5/23/23 5:47 PM
|-- Hosting Server: https://myorg.net/server at 5/23/23 5:47 PM
| |-- Relational Data Store: https://mydatastoreFQDN:2443/arcgis
|-- Federated Server: https://myorg.net/agsfed at 5/23/23 5:47 PM
Starting the backup process with the WebGIS DR utility.
Starting the backup for Portal for ArcGIS:
Url: https://myorg.net/portal.
Starting the backup for ArcGIS Server:
Url: https://myorg.net/server.
Url: https://myorg.net/agsfed.
Starting the backup for Relational ArcGIS Data Store:
Url: https://mydatastoreFQDN:2443/arcgis.
The following ArcGIS Server has been backed up successfully:
The backup of ArcGIS Server has completed in 00hr:02min:08sec.
The following Portal for ArcGIS has been backed up successfully:
The backup of Portal for ArcGIS has taken 00hr:09min:02sec.
The following Relational ArcGIS Data Store has been backed up successfully:
The backup of Relational ArcGIS Data Store has completed in 00hr:10min:31sec.
Failed to back up Portal for ArcGIS.
Exiting the WebGIS DR utility.
Any ideas? The output says the portal has been backed up successfully and yet the utility still fails to produce the backup file. Its a file share type backup, all of my shares privileges are in place, Java Home environment is in place....
David
