I have two questions:
1- Is the EC2 instance deployed with the AWS CloudFormation template "arcgis-enterprise-allinone.template.json" compatible with a "four-core server" ArcGIS Enterprise license?
2- Both the "arcgis-vpc.template.json" and "arcgis-vpc-dmz.template.json" deploy two subnets. Does the installation of ArcGIS Enterprise in a VPC with two subnets, each with a distinct EC2, requires two ArcGIS Enterprise licenses? Or, can the second installation be considered a "Failover license"?
Thank you very much
Hi Adriana
It's true that the VPC templates will create two subnets, but the allinone template will only create one EC2 instance in one of those subnets. The instance type parameter in the allinone template is where you define the "size" of your EC2 instance. By default it's m5.2xlarge, which, according to the AWS physical core equivalency list, has 4 physical cores, so you should be covered by your 4-core license.
Thank you so much for your valuable answer. It was very helpful.
So, do you think I could place the geodatabase on the other subnet?
Best regards
Yes, I would have a separate enterprise geodatabase, and, since the VPC templates create two subnets, I was thinking of placing it the private subnet of the "arcgis-vpc-dmz.template.json". Do you foresee any limitations to that? It would be a good though, to be able to estimate the costs of the implementation of each one of these CostFormation templates.
Thank you
