Hi D2M Users,
I just downloaded the most recent version of D2M (2023.1.1) - I have an advanced license.
I regularly process orthomosaics with this software, however, I noticed with the new version that there is now a "True Ortho" option under the 2D Template. I think I will definitely use True Orthos in the future, but my workflow only requires regular orthomosaics. No where in D2M can I find where to check off regular orthomosaic as a product. By using the default checked off options while processing, it generates a 3 band true orthomosaic, but it does not produce a regular orthomosaic anymore from what I can see?
In the D2M documentation, it says you are still able to produce a regular orthomosaic with the 2D template: https://doc.arcgis.com/en/drone2map/latest/help/processing-options.htm
When checking off products in D2M however, there is nowhere you can specify a regular orthomosaic. The options are:
- Image Collection
- True Ortho
- DSM
- DTM
So does the regular orthomosaic autogenerate in tandem with one of these other products?
I require the old orthomosaic option as they are much quicker to generate and all of our organization's orthomosaics are housed in a single MDS, which we want to keep standardized.
Thank you in advanced. I attached a couple of screenshots from my D2M options.
Emma
