Does anyone have an update for this BLOG on the Esri Australia site?
https://esriaustraliatechblog.wordpress.com/2021/04/01/gda2020-arcgis-online-and-the-web-mercator-dilemma/
The reference details that the NTv2 grid for ArcGIS Pro is useful for standard GDA2020 web maps but should not be used when mixing datums and Web Mercator Basemaps in a publishing workflow.
The blog is two years old and we are wondering if there is any change to the available conformal transformations and Web Mercator / GDA2020
You would be advised to contact esri tech support, but... this blog is more recent, just slightly
New GDA2020 transformations for WebGIS | Esri Australia Technical Blog (wordpress.com)
Hi, I'm the original author of that post.
Publishing to ArcGIS Online will do one of two things:
ArcGIS Online doesn't support grid-based (NTv2) transformations for Hosted Feature Layers. Only the default. ArcGIS Pro, ArcGIS Server and Field Maps can support the grids if they are installed. They are large, and a lot of countries have them, hence the limitation. If you publish a hosted feature layer with a NTv2 grid-based method, it will be dropped from the service definition.
So if you want to use a grid-based transformation, you should do it BEFORE or DURING publishing to a Hosted Feature Layer. i.e.
As Dan mentioned, there are new transformations now. Originally they didn't release any direct transformations between GDA2020 and WGS84. Now there is, and they are poorly named in my opinion. Key to note:
Personally if I am publishing to ArcGIS Online I would:
Any other questions feel free to post, might write an updated blog this weekend.
