Hi, Norwegian Distributor supportteam here.
Just had a supportcase for Drone2Map (2.3). Notice the camera model for Hasselblad L1D-20c is "way off" as it is defined in Drone2Map 2.3.
For example Principal Point in D2M 2.3 is defined as (mm) : 6.94, 3.98
In 2022.1.2 the same parameters are 0.03, 0.01 respectively (and still millimeters) !
Gives "interesting" results 😄
