A method to easily identify "orphan points" (i.e. points not covered by a line).
Original discussion of this ide can be found at the link below.
https://community.esri.com/t5/arcgis-parcel-fabric-questions/select-points-that-are-not-covered-by-lines/m-p/1148718#M602
Thank you!
That's one of the built-in topology rules, isn't it?
Hi Josh, you had me thinking there for a minute... The reason that is not available as a topology rule is that there is only one point feature class that's shared between all parcel types. You could add the rule "Point must be covered by end point of" for all of your parcel types' lines, and for your connection lines, but then you would have an error feature on all of your points except for those points that happen to be on the endpoint of a line of ALL the parcel types that connected at that one location, and there would also have to be a connection line's end at that same location: that'd be a rare case.
Implemented in ArcGIS Pro 3.5 as a geoprocessing tool called 'Find Disconnected Parcel Points'
Sign in to post, follow content, and more. New here? Register for free.
