As I am resuming working on a new project, or if you are trying to clean up your projects. I was wondering why there was no Preview map to review the past maps. If you recall ArcGIS ArcMap, it has the enable to turn on the thumbnails to view each map?
Why was there no tab to switch from list to preview when you open your ArcGIS Pro and at the left menu under Open. All you can is see the list with the project path?
Are there any plans ESRI will implement on that for the next new version in the future?
