In my quick capture app, I want the user to be able to input some notes.
I have added a notes field to my target layer, when I have the button in the quick capture app configured to the 'fixed value' state the project saves ok.
When I update it to 'button user input' and specify the details and then try and save the project I get an error saying "Can't save the project due to an unknown error. Please try again. If the error persists please contact ESRI Support".
I have tried removing the button, removing and readding the field in the layer and following all helpguides online but no luck.
I used the following - https://community.esri.com/t5/arcgis-quickcapture-questions/quickcapture-project-won-t-save-input-variable-for/m-p/1158743#M798 resolution but this also didn't work.
-- STEPS TAKEN --
- In button data configuration, for capture fields it is by default set to ‘Fixed value’ for my field ‘damage_notes_polygon’
- I update this to button user input with the following configuration
- When I try to now save the app, there is an error (which is resolved by setting the field back to fixed value)
