Using 2022.1.1 most current, and have great Model products using GCP's and Check Points. Defined Project Coordinate System clearly at start in "UsFt" (Projected) and correct Z (Height) in UsFt. After processing the DEM/DTM, checking a Point location is showing the Values are in METERS..... yet in fact they are the Correct for "UsFt".
Simply put, what have I missed to have Mensuration Results saying in METERS when the values are truly USFT ? Attached image clip from project, and you can see the USFT curser values are SAME as the Mensuration Results that say METERS (± given pick point).
Having same issue with the Orthomosaic, and the 3D Point Cloud.
When I push output data to OpenRoads Designer (MicroStation DGN), the header units are saying METERS, so imports are not being placed correctly.
Any assistance on where I've defined incorrectly would be appreciated. Thanks, in advance.
