According to the documentation for the Enable Enterprise Geodatabase tool, you must provide the "keycodes file that was created when ArcGIS Server was authorized."
Is there an alternative way to generate the keycodes file without installing ArcGIS Server? My preference would be to deploy a production enterprise geodatabase before setting up the production ArcGIS Enterprise site.
Based upon how long it took to set-up things in the development environment, I will be waiting a while for my IT to set-up things so I can install ArcGIS Enterprise in a production environment. Getting a SQL database set-up is a much faster process.
However, I'm not sure if that is possible. I am looking for a solid answer. Thanks!
