I am using ArcGIS Pro 2.8.2 and the Summary Within Tool doesn't work properly. For example, I can not get the counts of points within polygons (unit of analysis). I am using Analysis Summarize Within tool.
Also when summarizing an attribute (for example, population), it doesn't give me the correct calculated summary. In my case, if there are 5 intersecting polygons, it is expected that the population of the 5 polygons should be summed up but it gives me a very different value which is not correct and I can't figure out how it has been calculated.
In order t solve the issue, do I need to update the software? I can also see this new GeoAnalytics Summarize Within tool. Is this the replacement of the older Analysis Summarize Within tool? I tried the GA version but it doesn't work with point data.
I have been using this tool for a while and never had a problem but for some unknown reasons it doesn't work as it did before. I do appreciate it if someone can help me to figure out the issue.
Thank you!
