When adding a description to a layer's metadata and publishing as a Map Service to Portal, the rest endpoint shows the HTML tags for the Description and makes it very difficult to read. Is there a way of removing these tags or converting the description field to a simple plain text box? This isn't the case for the summary field.
Otherwise, is there a better way of viewing individual layer metadata for a multi-layer map service other than via the rest endpoint?
