I've created a Survey123 form which contains three separate repeats (going into three separate feature layers on AGOL). A user has accidently added an unwanted repeat record to one of the repeat sections, and submitted their data. What is the best way to delete this single record from the feature layer on AGOL without also deleting all associated records submitted under that parent record? If I delete the record in Survey123 it deletes the entire response including all other repeat records.
Any help would be much appreciated,
Thank you.
