Hi all,
I'm experiencing the problem that the legend items are pixelated/garbled when I use the print widget.
This issue is described here: https://support.esri.com/en/technical-article/000011636 Although the issue is not limited to PDFs but appears also in other formats.
The described workaround won't work in my case as I can't login to the group manged service account.
Does someone know of an alternative workaround/solution?
Enterprise Version is 10.7.1
Thank you,
Marco
