My end game is to migrate to another ArcGIS Server on another box and I read ESRI prefers you setup a network shared folder with full rights to the administrator account running AGS. You then can use AGS Manager or ArcGIS Desktop to alter the path of the config-store folder and the 4 sub folders in server directories. The config-store folder successfully changed to the network share. However, I’ve tried many different times to change the directories folders with no success. Mostly the errors are “Method argument cannot be null”. Sometimes it’s “cannot use that folder because it’s in use by another site”. I’m just out of ideas. Does anyone have any advice or things to check for? Ideally I need this working before Monday. Thank you in advance!
