Hi everyone,
I am getting this error message when I try to import a feature to my Postgresql database via ArcGIS Pro. ERROR 000210: Cannot create output...
Has anyone had this problem before?
Isabelle
Rename the sde connection file to start with an alpabet. Also could you copy the SDE file to a shorter, non-OneDrive path with no space or special characters in pathname.
e.g.:
\GreenDestinations\CSM5432.sde
@JayantaPoddar Thank you for your message. I have tried it and it still doesn't work.
@JayantaPoddar Hi again, I have tried everything and still get this message. Does anyone else had this problem before? Thanks
I'm having this issue as well... Has anyone found a resolution?
@IB3 and @moremeowbell or if anyone else is still facing this challenge like I did just now. I found this resource to be very helpful. You can take a look at this here - https://pro.arcgis.com/en/pro-app/latest/help/data/databases/add-the-st-geometry-type-to-a-postgresql-database.htm
This solved my issue. Apparently, ArcGIS requires some special permission in the DB.
