I am attempting to launch Field Maps from Survey123 via URL parameter and pass attributes from Survey123 into a specified feature in Field Maps using the using the Field Maps referenceContext=updateFeature method.
The problem is that I can't figure out how to pass a specified attribute from Survey123 as a URL parameter. This is easy to do going from Field Maps to Survey123, but not so much going the opposite direction.
Basically I've got an guid attribute called Pole_Key in Survey123 that matches the GlobalID of a point feature in the Field Map. I want to use that Pole_Key to open and edit the corresponding record in Field Maps. How do I pass the Pole_Key attribute as a URL parameter from Survey123?
