I have found this : http://blogs.esri.com/esri/arcgis/2011/11/21/adding-labels-to-arcgis-online-web-maps-part-1/a small summary : �?� design labels for your map layers in ArcMap; �?� convert labels to annotation; �?� use the Feature Outline Masks tool to create polygon feature geometry from annotation;then you choose you you want to import the features in your map (services or shapfiles).With best regards
mh... Have you zipped your shapefile ?At which step you get the error ? Can you upload your data and then you can't visualize the features ?Check that you feature class (from annotations) doens't contain more than 1'000 features. If it is so, just divides your feature class (from annotations) in a few shapefiles.
