I've got ArcGIS Enterprise 10.8.1. I'd like to have an indicator count the number of features that intersect with another feature. Is that possible? If so, what's the best way to do it?
Will the feature change and the count at the intersections be dynamic? Or will the dataset be static? Also, will you be publishing this data online or just in a local project/ database?
The dataset is mostly static, but the indicator will change.
I've got two feature classes--one set of points and one set of polygons. I'd like to have an indicator on a dashboard that will show the number of points inside the polygons in the current map view.
I'm thinking I might be able to do something with Arcade, but the "Advanced formatting" option doesn't show up in the dashboard indicators. Is that available in Enterprise, or is it an AGOL thing only?
I think you are looking for attribute from intersection?
https://github.com/Esri/arcade-expressions/blob/master/any/attributeFromLargestArea.md
That's the goal. But I can't figure out if there's a way to get that using the Ops Dashboard. When I make an indicator, I don't get a button that says "Advanced formatting" anywhere. It's only giving me the option to use the preconfigured indicator tools, not any Arcade.
