On ArcGIS Enterprise, it is possible to configure a custom S3 region when registering a cloud store:
https://enterprise.arcgis.com/en/server/latest/manage-data/windows/registering-your-data-with-arcgis-server-using-manager.htm#ESRI_SECTION2_D57ED56F5E1C4CB4A47B78E0BE775541
But I am under the impression that it is not supported for webgisdr ... ? There is no variable for the S3 private URL:
https://enterprise.arcgis.com/en/portal/latest/administer/linux/create-web-gis-backup.htm
Seems strange: did I miss anything ?
You should be able to create the regionsforcloudstorage.dat file within the webgisdr tool folder. Somewhat follows this doc:https://enterprise.arcgis.com/en/server/10.6/administer/linux/configure-regions-for-cloud-stores.htmbut move it into the webgisdr tool folder instead. There is a bug about it not working when it's in framework\etc, which should work:BUG-000138487 WebGISDR tool does not recognize custom entries in regionsforcloudstorage.dat file in Portal's framework/etc directoryWorkaround:
Download regionsforcloudstorage.dat file from http://arcgisstore105.s3.amazonaws.com/regionsforcloudstorage.dat and append necessary region to JSON. Save file and place in <Portal installation directory>/tools/webgisdr directory, then re-run WebGISDR tool.
Example JSON for ap-east-1:
"name": "Hong Kong",
"id": "ap-east-1",
"s3endpoint": "s3.ap-east-1.amazonaws.com"
S3 Endpoints can be referenced from https://docs.aws.amazon.com/general/latest/gr/s3.html
Hi @JonathanQuinn ,
Thanks for the confirmation. Please let me know if you get any interesting information about non-default regions. I find the documentation really light about it now only for webgisdr backups (cf. https://community.esri.com/t5/arcgis-enterprise-in-the-cloud-questions/portal-for-arcgis-content-on-s3-compatible-storage/m-p/1121969#M378).
Thanks !
It is still safe, I'm not completely sure why it was removed. The only reason why you'd want to use that file is if you're trying to use a region that isn't already supported by the SDK that we are using. If that's the case, the DR tool should look at a local file first and if it can't find it, look for the one in portal, which is the bug. We'll address that, but moving forward, it'll still expect that non-default regions are added to a manually created regionsforcloudstorage.dat file. I'll see what we don't have that documentation anymore.
Any thought about the future of "Configure ArcGIS Server to access a local file" ?
Is it safe ? It's still gone from the documentation.
Hi @JonathanQuinn,
Thanks for your reply.
Indeed, your workaround does work but I wonder about the perenity: the documentation you linked about the 'regionsforcloudstorage.dat' file is from 10.6 and is removed starting from 10.8.
Why not including this type of configuration in the webgisdr config file directly ? Is it something you are trying to improve or something you are trying to get rid ?
Will it break at the next release 🙄 ?
Nicolas
