Hi guys,
I am having a huge headache with my portal. hope you can help me in finding the solution.
after having installed portal and the two web adaptors for server and Portal (all the setups for 10.3.1) I cannot access the portal through the web adaptor.
the link https://FullNameOfPC/webadaptorname gives me the error:
"Request is not available in this context"
I can access the Portal through the 7443 but not the webadaptor.
Same for Portaladmin and Sharing/Rest
From PortalAdmin, the webadaptor seems to be registered.
I would probably need to reconfigure the webadaptor but I am not really sure how should I do.
Could you give me a hint?
I thought to unregister and then register again or uninstall and install again
(At the moment, since this is still a testing environment, the Certificate is a self signed one)
Thanks.
