In ArcGIS Enterprise 10.5,when i publish Map service through database (Oracle),identify not shown values on my map click.
Any solution will be highly appreciated
via what means are you consuming the service e.g. Pro, arcmap or Portal etc? If it's a Web Map it may be as simple as enabling popups https://doc.arcgis.com/en/arcgis-online/reference/configure-pop-ups.htm
https://doc.arcgis.com/en/arcgis-online/create-maps/configure-pop-ups-mv.htm
I am using ArcGIS Enterprise10.5 Map Service.
Issue facing screenshot.
I just posted in your other post about this: https://community.esri.com/t5/publishing-and-managing-services-questions/popup-not-shown-results-through-registered/m-p/1087801#M503Also may want to look at upgrading the Oracle geodatabase also to supported version, if it is 10.0 currently. I do not think that will fix the issue, but would not hurt.
