The Survey was created and published from survey123 Connect 3.9, then republished with 3.12.
There is a repeat section with a photograph and text field input. But saving the form to drafts only ever saves the FIRST set of data that was entered. Returning to the form and adding data (in this case a photograph and comment), then resaving the draft never works. Only the first set of data entered into the repeat is saved. Subsequent additions are lost.
This is the workflow that shows it.
- Start a form, input everything, take a photo and add a comment.
- Hit the X in the top left, “Save in Drafts”, turn off app (swipe away).
- Reopen the app, hit the arrow to add a new photo, add comment.
- Once I open up the draft again, the photo and comment I took the second time is gone
Is this behaviour a bug? or resulting from the use of the repeat? i have read of versions of this behaviour being patched on the site. But not quite this. And it continues with the latest updates of survey123 and connect (3.12).
Has anyone else observed this or come up with a solution / workaround?
thanks.
