I've created this post to highlight an issue that hasn't been solved so far in my knowledge.
I'm trying to include some PDF documentation in my survey, with an HTML link to a local file. This local file is bundled with the survey via the 'media' folder.
I've used DeonLengton's method below to create the HTML link, and can confirm it works for Windows. However the HTML link generated for Android doesn't seem to work, even though file path is correct.
Does anyone know what is the correct file path for Android to reach the Survey media files?
Android file paths I've tried:
- /storage/emulated/0/Android/data/com.esri.survey123/files/ArcGIS/My Surveys/{UniqueSurveyId}/esriinfo/media/Doc.pdf
- file:///storage/emulated/0/Android/data/com.esri.survey123/files/ArcGIS/My Surveys/{UniqueSurveyId}/esriinfo/media/Doc.pdf
- file:///Internal Storage/Android/data/com.esri.survey123/files/ArcGIS/My Surveys/{UniqueSurveyId}/esriinfo/media/Doc.pdf
Link to create HTML links: https://community.esri.com/t5/arcgis-survey123-blog/html-links-for-survey123-to-just-about-anything-work-in-progress/ba-p/894670
Link to replies where several users faced the same Android file path problem: https://community.esri.com/t5/arcgis-survey123-questions/survey-123-hyperlink-to-local-file/td-p/818779/page/2
