I'm wondering if there is tile cache compatibility from an ArcMap published map service to an ArcGIS Pro published map service.
For example, let's say I were to overwrite a cached map service originally published from ArcMap 10.7.1 with the same cached map service published from ArcGIS Pro 2.8, where I keep the existing tile cache. Should I expect this to work seamlessly? Or does the tile cache have to be recreated in order to be recognized by the ArcGIS Pro published map service? BTW, I am using ArcGIS Server 10.7.1, Windows, stand-alone.
I did a couple tests of this scenario to see what would happen - the existing tile cache was not recognized.
But I'd like to get input from anyone else who has had experience with this.
