Hi all
I have a feature layer in my portal. I am owner and the layer is sensitive, so only a few people should see it.
I have a group for that called gr1.
Testing with 2 users u1 and u2.
if user is not part of the gr1 they shouldn't see the layer.
if user is part of the gr1 they can see the layer.
Results:
U1 - admin on portal, not part of gr1 = can not see layer.
U1 - admin on portal, part of gr1 = can see layer.
So u1 seems to have expected behaviour.
U2 - admin on portal, not part of gr1 = can see layer. (1)
U2 - user on portal, not part of gr1 = can not see layer.
U2 - admin on portal, part of gr1 = Not tested due to 1 above.
The only difference is u2 has two accounts on portal - one admin (L2) and one user (L1) with 2 different emails.
Question:
Why the different behaviour?
If a user is admin but not part of a gr1 they should not see the layer. Is that correct?
So how come u2 saw the data as admin, but not part of gr1?
How can a layer be set up on portal to be visible to specific users only?
Portal 10.6.1. Using SAML auth.
