Hi
I’m working on a python script to automate publish imagery service and need to create a ags file as input. However I’m unable to change the user type from User to either ‘admin’ or ‘publish’ type even I have the admin privileges with the Esri Help Doc. Any thoughts? Thanks
For your info, I’m using arcgis pro 2.7 and the a federated imagery server.
https://pro.arcgis.com/en/pro-app/latest/help/projects/connect-to-a-gis-server.htm#ESRI_SECTION1_CC20626EF9BF4A85AEEDCA22E956CBD5
Hey,
My understanding is once your server federated with Portal then it will have all the privileges associated with your Portal role, which means you can directly share your contents to your portal. In this case, I would suggest to create a ags file with saved credentials for creating SDDraft and SD file. Then use arcpy.UploadServiceDefinition_server(sd,imgaeryServer) to publish service. Here, imageryServer is the URL to your imagery server.
Hope that helps.
This does not feel like a good solution, in arcgis 10.6 it was very simple.
