Is it possible to customize the fields displayed in the 123Survey inbox?
Indeed, the display is not very ergonomic by default.
Thank you.
Is this what you're looking for?
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsforminstancename.htm?adbsc=social_branding_20180817_2493321&adbid=1030273013923512320&adbpl=tw&adbpr=3322007898
In the settings tab of your form you'll see a column called 'instance_name'. This is where you can customize the inbox appearance. Here's a couple examples:
This one is using the surveyor's name as the instance name.
This one combines the responses from 3 separate fields.
I hope this helps!
