This is very helpful to me.
Liran
Excellent read, thank you.
Nice intro, thanks
Great post Anon 🙂 just to bolster this slightly, here are the relevant documentation links which constitute the above post:
https://learn.microsoft.com/en-us/azure/active-directory/saas-apps/arcgisenterprise-tutorial
https://enterprise.arcgis.com/en/portal/latest/administer/windows/configuring-a-saml-compliant-identity-provider-with-your-portal.htm
One extra thing, 11.1 security scans now check for SAML encryption assertion - it is recommended this is enabled.
This is a great article.
@A_Wyn_Jones. Our IT is switching the userprincipalname and I am wondering if I can switch the Required claim to user.objectid rather than the userprincipalname. If I can make the change, would this circumnavigate user access issues when IT switches the userprincipalname? Thanks.
Hi @HeathAnderson,
If your query is regarding your IT changing the IDP claims, please make sure they're compatible with the User Profile Mappings found here:
https://enterprise.arcgis.com/en/portal/latest/administer/windows/configuring-a-saml-compliant-identity-provider-with-your-portal.htm#:~:text=User%20profile%20mappings
Even more information can be found here:
https://github.com/Esri/idp
Hope this helps!
A
I Don't have the subscription of SMAL on my azure portal what I have to do for the azure authentication on ArcGIS portal any alternative??
@zainabzia
What version of Portal are you running?
Would using Web-tier authentication be an option for you? This method is available from 10.8 - current release (11.3)
https://enterprise.arcgis.com/en/portal/11.3/administer/windows/about-configuring-portal-authentication.htm#ESRI_SECTION1_66C3475137F544719F1CA3129B62D939
