After publishing a public map service we noticed that labels (created at the ArcMap level) show up when adding the full map service to an AGOL Web Map: https://arcgis.gis.lacounty.gov/arcgis/rest/services/DRP/ZNET_Public/MapServer
But when adding the individual layer from the map service to the AGOL Web Map, labels do not come across: https://arcgis.gis.lacounty.gov/arcgis/rest/services/DRP/ZNET_Public/MapServer/2
Has anyone run into this issue before?
Any work arounds you have found, or the reason why this might be occurring?
Thank you!
Hi Liza
When adding the full map service, the map viewer sends an Export Map request to ArcGIS Server and it is rendered server-side.
When accessing an individual layer, the map viewer sends a Query request to ArcGIS Server, returning geometry which is rendered by the browser. It would appear that for this scenario, the map viewer doesn't construct a text symbol to render the labels, which is why you don't see them.
In somewhat of a workaround, you can add the full service to the map and remove all of the layers that you don't want to be part of the TOC. This sends a Dynamic Layer request to ArcGIS Server, and the labels are displayed.
I've checked in the latest Map Viewer Beta and the behavior is the same, but at least the new version comes with more labelling options than the original map viewer. Might be worth adding this as an idea if there isn't already one on GeoNet 😊
Cheers
Craig
Thanks Craig, our workaround right now is using the whole map service. I also played around with Map Viewer Beta and the labels, it's not going to work for this instance but its a good option.
Thank you, this worked for me.
I’ve encountered a similar issue when loading an individual layer that uses display filters. When I load the full map service, the display filters work as expected. However, if I load just an individual layer, the display filters do not apply.
Could this be because the map viewer is using a Query request? We need to load individual layers rather than the full service—do you know if there’s a workaround for this?
We are running Portal version 11.3.
